Home > Maintenance & Modifications > Hydraulic fluid leak. Advice much appreciated.
Gas-guzzler
United Kingdom 2007 Range Rover Sport TDV8 Sumatra Black
Hi guys,
Happily sitting nice and warm with the car idling outside supermarket shattered by a ping from the instrument cluster and red air suspension warning light accompanied by caption “STOP SAFELY, SWITCH OFF ENGINE.” Oh no!
Warily looked underneath expecting to see ruptured hydraulic line (they are heavily corroded) and saw the hydraulic leak coming from the big nut in the picture. Fluid was dripping steadily (that yellowish dot on the nut is fluid dripping) just wondering if that nut is a drain plug, possibly like an oil sump plug with sealing washer which may have failed. May I also ask what that unit that the nut is screwed into is please? Hydraulic lines join in at the front and out at the rear of the unit.
Any thoughts as always gratefully received. My Autel AP200 also gave the fault code in the other photo.
Thanks.
Post #628155 Fri Nov 11 2022 11:18pm
Disco_Mikey
Alloy part of the valve block above the plug has corroded away, causing the o ring to pop out and dump its fluid Big Cry
Post #628156 Fri Nov 11 2022 11:38pm
Gas-guzzler
Got you. So I’m guessing that the o ring should sit in a shallow recess? I’ll whip out the nut tomorrow and have a look. Thanks for your input.
Post #628160 Sat Nov 12 2022 1:31am
Gas-guzzler
Yep, hats off to Disco_Mikey. Spot on diagnosis. Block is corroded at the rear of the plug. Is there any other fix for this than a new block valve assembly. I’m tempted to take it off the car, get some weld put on there then re-machined a bit like a curbed alloy wheel repair. Or there’s eBay, couple on there sub £200 but that’s still £200 I don’t have at the moment. Crying or Very sad
Any and all suggestions gratefully received..
Thanks.
Post #628209 Sun Nov 13 2022 10:09am
Disco_Mikey
The issue there, is your highly unlikely to find anyone to repair in situ (without bodging)
Realistically, the block needs removing from the car, which involves releasing the front and rear pipes which will likely be seized in the block, and probably quite fragile due to corrosion on the pipework
It's a whole can of worms Neutral
Post #628211 Sun Nov 13 2022 11:07am
Mccolganm4
I was in your situation a couple of months ago. Again my pipes are rotten and need replaced too. Looking at near on 1000 quid for parts alone I tried a bodge to keep me going until I can gather parts. I fitted a new seal and wrapped PTFE tape round the threads.
I've done a few hundred miles and no leaks so far, I have also got a 2nd hand valve block and new rear pipes in my shed and am planning to get the fronts ordered soon. I'm realistically thinking it'll be the new year before I need to bother though.
It's not repaired and I know that but it makes the car useable just now
Post #628213 Sun Nov 13 2022 12:20pm
Gas-guzzler
Thanks gents. I would be removing the block valve to get it repaired but just looking at my rusted hyd lines make me wince. It is a real can of worms indeed! I’ll get a new seal and PTFE tape and give the temporary repair a go. And then as you did, start saving and collecting parts for a repair when I can afford it. Huge invoice though for the lines, block valve and labour of the body/chassis split. Won’t expect much change out of £4k for that lot. Ouch!
Post #628229 Sun Nov 13 2022 11:11pm
Grimble
In my old toolmaking days we would have made a tool like a bolt that screwed in but had a simple rotating collar with a cutter to re-seat the face. The loss of half a millimetre or so of the threads would be negligible. We used to regularly make as a sideline, valve re-seating cutters.
Other option is to use a soft metal washer (copper or aluminium) that may compress enough, but retain mechanical strength to resist the hydraulic pressure. Looking at the seating face, I dont think a 'Dowty' type washer would work, but also worth a try. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #628239 Mon Nov 14 2022 5:55pm
Gas-guzzler
Those are both great suggestions, thanks, I’ll make enquiries to see if I can make one of them work. Especially like the tool for re-seating the recess a bit deeper.
Post #628243 Mon Nov 14 2022 6:20pm
Gas-guzzler
I have made a bit a progress with a new seal and PTFE tape. It’s an ugly bodge with part of the new, slightly fatter seal bulging out around the corroded part on the seat, but it’s not leaking at the moment. But, the RED air suspension light still illuminates with the ping after the cars started. There is still ACE fluid in the reservoir but it’s below MIN line. I’ve ordered some which hopefully be here tomorrow. Does anyone know if the RED air-suspension light is hyd pressure triggered, or quantity in reservoir please?
Also, after removing filter and plug will the system need bleeding or just top up the fluid and keep an eye on it?
Thanks
Post #628245 Mon Nov 14 2022 6:28pm
Mccolganm4
Good news about the leak. I think it is pressure related but should so off with a top off and a drive. Mine did anyway. Good luck
Post #628247 Mon Nov 14 2022 6:55pm
Gas-guzzler
Thanks man, I’ll top it up and take it for a drive and let you know how I get on. Oh, and I’ll make sure I’ve got some spare fluid which I’ll carry in the car. Thanks again. Thumbs Up
Post #628248 Mon Nov 14 2022 8:19pm
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Here is my pennies worth , I had the seal pop out , so I found a large dowty seal for the face while using loctitw hydraulic on the threads, I think I posted this
Post #628679 Mon Nov 28 2022 11:23pm
