Home > General > Parts |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1849 |
The L322 is the Range Rover and the L320 is the Range Rover Sport 2023 P440e SE Dynamic on order -cancelled
Wed Nov 02 2022 1:47pm |
TommyM Member Since: 02 Nov 2022 Location: Belfast Posts: 19 |
Thanks my friend MOT here next Mon so just in case of failure I needed to know in case I gave to order parts |
Wed Nov 02 2022 2:02pm |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 |
Good luck with the MOT ( we don't have those Here) but not a bad idea. |
Tue Nov 08 2022 5:51pm |
Thanxs m8, failed but repairs in hand |
Fri Nov 11 2022 12:47pm |
So you have a L320, RRS,i sorry to hear you failed the MOT.
Fri Nov 11 2022 3:58pm |
Rear brake pipes, bolt missing from osr brake assembly and blown brakelight, it's govt test centres here, getting into garage on 28th earliest I could get retest for 2/12 now have suspension light coming on suspect compressor, need to talk to.my mechanic who is off for a few days |
Fri Nov 11 2022 5:43pm |
Hey Tom,do you have scan tool to give indication of Suspension light/compressor failure? |
Fri Nov 11 2022 7:20pm |
Sorry m8 no, was to get it done today but mechanic couldn't get to me house fire at top.if Street, going to try Monday, will say this only occurred after up for mot here in Belfast with their rli g rocki g table they use hoping cos car was lifted to test may just be sensor issue, knowing my luck will be compressor and valve blicks |
Sat Nov 12 2022 7:48pm |
