Home > In Car Electronics > RR SPORT 2007 XENON HEADLAMPS
Mantaraman
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
One of the Xenons has stopped working, can anyone suggest which component(s) I should replace? | understand there is the lamp itself plus aa ballast unit, anything else?
Thanks.
Post #628065 Wed Nov 09 2022 12:17pm
Disco_Mikey
Bulb
Ballast
Wiring Fault
BCM
Any of the above (and more) can cause the a headlight to not function
Post #628067 Wed Nov 09 2022 1:36pm
Oldandconfused
Am I right in thinking that the quality of light output deteriorates in time and the best practice would be to replace both and keep the one that still works as an emergency spare?
Just asking out of curiosity, mine are fine (well that's done it now).
Post #628074 Wed Nov 09 2022 6:43pm
peterjj
Australia
'quality of light output deteriorates in time'
yep. I replaced the xenon bulbs only and made a huge difference. Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Post #628083 Wed Nov 09 2022 10:15pm
Mantaraman
Problem solved, thanks for the suggestions. Replaced the lamp - Osram from ABD, £28 - and working fine now.
Thanks to Youtube, removing the headlamp unit was easy and needed to replace the sidelamp bulb anyway.
End.
Post #628210 Sun Nov 13 2022 10:20am
