Kzwpoas1
Front diff rebuild. Set-up specifications (LR006011) | |
Hello,
Can anyone point me in the right direction for the correct factory specs for a front LR006011 front diff rebuild?
I have a RRS HSE, 3.6 TDV8, 2009. Original diff part number: LR006011.
1. Pinion bearing preload (used)
2.Backlash
3.Ring gear bolt torque
4.Bearing cap torque
I will have my front diff rebuilt by a specialist but I want to double-check the exact specs with him as I am not in the UK.
I will use a quality Timken bearing kit ( DA5039)
Thanks and cheers.
Mon Nov 07 2022 1:03pm |
