![]() | Home > Orders (L461) > 440e Cabin Preconditioning |
Milky400 Member Since: 11 Aug 2022 Location: cambridge Posts: 92 ![]() ![]() |
It allows you to set timers so you don’t need to open the app and press the button. That’s what my understanding is |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1873 ![]() ![]() |
Sounds like nothing new that's not on the P400e, probably paying for what used to be included? |
Not sure about the p400e but all previous JLR’s I’ve not been able to set the time it comes in as I’ve never paid the extra, just open the app and start it. |
R22Flyer Member Since: 04 Feb 2007 Location: South Posts: 111 ![]() ![]() ![]() |
I have this option, you get an extra remote which has about a 400m range, it start the FBH an warms the car up, it work independently to having the app connected, I think it’s for areas or countries which have no cell signal, also you do not need a subscription for it to work.
rangersport Member Since: 29 Oct 2012 Location: West London Posts: 64 ![]() ![]() ![]() |
On the new model, I can see an option on the app to set departure time and 'precondition' including 30 mins climate. So I assume you can schedule it without the added option, which I did not tick. Not that I have tried it to be honest, but it is definitely there in the app.
GJW1 Member Since: 19 May 2015 Location: UK Posts: 447 ![]() ![]() |
Before the app if you chose the pre heat option at a cost you got an extra keyfob to start the heating through a fuel burner not by starting the car which the app does.
You have a FBH on a P400e petrol car? Must admit I did not see that option when buying mine. The app has always works when I need it and if no mobile signal the I guess I could use the menu in the car before leaving it. EDIT: Just found the old brochure, it was option 022LB for £1.080. Still would like to know what it starts, FBH or engine? 2023 P440e SE Dynamic on order -cancelled 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! |
Cooperman Member Since: 02 Nov 2013 Location: Uk Posts: 75 ![]() ![]() |
I had the pre-conditioning option on my RRS2 V8 diesel, have it on my Cayenne, and have specced it for my 510e (which i do not know whether i will ever actually get!). I love it - just press the fob from the bedroom when I get up, then 45 mins later step into a warm demisted/ defrosted car. It does not start the engine. You can also start it from the app (on the Porsche), so can pre-warm the vehicle in say the train station car park before you arrive.
Yes defo has a FBH on the petrol for this option, I believe the Hybrid also uses electric heating to warm the batteries and the cabin, so not sure why this car was speced with it,
Thanks for posting that, agree not sure it is necessary to spec it.
norscot Member Since: 08 Oct 2013 Location: Scotland Posts: 18 ![]() |
Will the cabin pre-conditioning not be electric heating powered by the mains, so you are not using battery to heat car from cold, or having to start the engine? No way it'll be a fuel burning heater on a plug-in hybrid. |
Yes it a FBH on a plugin Hybrid, look at the pictures, I believe it to heat via mains if plugged in (I do this at work everyday) then if the temo is below 10C it uses the FBH to aid heating, it does not start the engine, in the connected app I have the choice of electric or engine heating.
Looks like you're quite right, I didn't look at the pictures. Guess it means you have the best of all worlds, to pre-heat in any situation. |
