![]() | Home > General > gap IID (should i or not) |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Personally I think they are worth their weight in gold, you will soon recover your cost against dealer hourly charges at least. There is also a very good s/hand market for them so if you sold it later you would recover a fair bit of your investment.
loonyball Member Since: 29 May 2019 Location: ballymena Posts: 30 ![]() ![]() ![]() |
thanks col for your feedback, i have a maxi-dial tool at the moment and it really is very good with jaguar/land rover but its not for in depth diagnostics nor can it programme, so i think i might just have to bite the bullet, thanks |
As Col says they are worth every penny that you won’t spend at a dealer. Like everything it’s a leap of faith especially the first time you plug it in, red button syndrome. If you are unsure you can always ask first or afterwards. Consider a used one unless you’re desperate now. They go for around £325 posted second hand and a £25 fee to Gap to tie it to your car. Remember it has to be tied to your car to change anything. You can read anyones codes and clear them though. A neighbour has a full fat and I clear his codes or read them every so often.
Thanks lads for the info, just ordered one from jgs4x4 so i will post here how i get on with it, its being delivered by royal mail so i should get it around march next year !!! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
More likely they will tell you it isn't possible, however they've found that your brakes are dangerous and refuse to let you have the vehicle back until they have changed all of the discs and pads for £2k. ![]() 2008 TDV8 - it was a labour of love and is much missed |
ok lads, so my gap iid tool arrived today, got it unlocked to my car (2012my RRS 3.0 HSE) glad to report no fault codes at all
Mike H Member Since: 12 Mar 2022 Location: Nottingham Posts: 7 ![]() ![]() ![]() |
Hope the link works
Thanks mike, i followed the link you kindly supplied and now i have my FBH timer on the nav screen 👍
