Home > Technical > Help! Reduced performance and P0101 and P023D codes |
beerguzzler Member Since: 01 Apr 2018 Location: swindon Posts: 28 |
Hi All,
Mon Sep 26 2022 5:11pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 946 |
A little more investigation needed i think, the only time I have had restricted performance is when the egr valves failed,, which is not as common on the V8 as it is on the 2.7 but this was accompanied with whitish blue smoke and I can't remember any other issues flashing up on the dash,, only the eml. Black smoke I have found was intercooler hoses, reduced performance but no warnings on the dash just sluggish. 2010 RRS, TDV8
Mon Sep 26 2022 6:11pm |
Sorted,
Sat Oct 15 2022 4:22pm |
Good of you to share your solution,, always helps someone else. 2010 RRS, TDV8
Sat Oct 15 2022 7:49pm |
