Home > General > Nanocom - Different vehicle usage
mitdan27
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hi there all,
We have a Nanocom unit already which we use on a D2 TD5, is it possible to use this unit for reading of codes on my RRS 2010?
Ive seen loads of different options across the internet for different units and software, but it seems daft if we already have a unit that we can use, I just cant find anything which explains how we would go about it?
Any help greatly appreciated as I have a suspension fault which I need to read the code and id also like to be able to check it on a regular basis as it hasnt been properly scanned since i took ownership in September 2020
Many Thanks! Very Happy
Post #627394 Sat Oct 15 2022 2:01pm
karlos01
you should be able to but I would think you might have to download the software for it
my friend has Nanocom for a p38 and it won't work on mine as needs to be unlocked for the l320 that I have
Post #627397 Sat Oct 15 2022 3:28pm
mitdan27
Ive been doing some more research and managed to find that through the site you can purchase the unlock code by itself to use on the unit which is exactly what im after, still a good chunk of cash but worth it in the long run really!
Thanks for the reply Thumbs Up
Post #627400 Sat Oct 15 2022 3:59pm
karlos01
thats it trouble is they need unlocking to each different model
Post #627401 Sat Oct 15 2022 4:04pm
