Home > Technical > Warning light woes! |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Battery in good condition?. 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Oct 11 2022 3:58pm |
Gas-guzzler Member Since: 28 Dec 2021 Location: Paisley Posts: 64 |
Battery seems ok. I’d read that a bad battery can cause these symptoms so gave it a full charge and same lights still come on. I’ll get a battery health check done to see. Thanks for the suggestion.
Tue Oct 11 2022 4:15pm |
Following a bit of research I’ve decided to order a brake light switch as it’s a cheap fix stating point. The brake lights do work as they should and the EPB releases with the button when I press the brake pedal, also, I can hear the solenoid click to enable to auto gear-shift to move out of park and neutral but thought it worth a shot.
Tue Oct 11 2022 10:26pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 481 |
This is where you want to get the actual codes read instead of playing parts roulette. And just cause the engine fault has an old EGR code doesn’t mean new codes haven’t been added. That’s the problem with ignoring those kind of lights. Get the codes, do some diagnostics, then spend money on parts. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Oct 12 2022 5:16am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
Agreed. You need a proper code read done. Trying to second guess it is going to waste time and money. 2012 SDV6 - it's missing a couple of cylinders
Wed Oct 12 2022 11:37am |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
get the codes read as it could be anything one sensor could be causing the others to play up |
Wed Oct 12 2022 12:06pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Agreed with the above - I've been here and got that T-shirt (as has everyone else, probably!)
Wed Oct 12 2022 2:16pm |
That’s all great advice. Thanks guys. So, I’ve bought an Autel AP200 diagnostic tool and it’s shown a left rear wheel speed sensor which I’ve ordered from euro car parts. Hopefully be fitting it tomorrow. I’ll post here results. Thanks again. |
Fri Oct 14 2022 10:06am |
had same problem with mine abs sensor is easy to replace only a 10mm nut holding it in place |
Fri Oct 14 2022 12:00pm |
Thanks Karlos and to all who helped. Problem solved. I bought an Autel AP200 diagnostic tool which identified a fault with the rear left wheel speed sensor. Replaced that and all lights are now extinguished and car drives fine. Thanks again folks. |
Tue Oct 18 2022 1:31am |
Excellent thanks for posting the fix 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Oct 18 2022 7:25am |
glad it sorted out for you |
Tue Oct 18 2022 6:24pm |
