![]() | Home > General (L494) > MY17 Deployable Side Step Motor replacement question |
Been-and-dunit Member Since: 15 May 2016 Location: Burton on trent Posts: 145 ![]() ![]() |
Had the same fault but I just gave the step pivots a good pressure wash and plenty of wd40 then oil and alls well |
Drewlr4 Member Since: 05 Aug 2020 Location: South Devon Posts: 55 ![]() ![]() |
Had exactly the same issue and as previous post a really thorough clean of the moving parts and lubrication and all now good.
DZ Member Since: 28 May 2020 Location: Warwickshire Posts: 18 ![]() ![]() |
Hey guys,
3hcp Member Since: 04 Nov 2021 Location: Devon Posts: 79 ![]() ![]() |
Lee350 Member Since: 07 Feb 2022 Location: Norwich Posts: 20 ![]() ![]() |
how do your remove the steps to service? can you lock them in the out position to get to the bolts?
Leave the door open and it stays out
Mike London Member Since: 22 Jul 2014 Location: Cotswolds Posts: 56 ![]() |
Or turn on the ignition (don’t start the engine) unlock the doors and hold the side steps button (next to the boot release) until the orange light comes on next to it. You have 3 seconds to complete or start again. Steps will stay out either until you hold the button again until light goes out or you drive away at more than 5mph. 2014 RRS AB Santorini Black Last edited by Mike London on Sat Apr 01 2023 2:48pm. Edited 1 time in total |
John w Member Since: 25 Oct 2019 Location: Cranleigh Posts: 9 ![]() ![]() |
Another stuck sidestep sufferer here.
just posting this incase it helps others.
Rigman64 Member Since: 17 Feb 2024 Location: North Yorkshire Posts: 3 ![]() ![]() |
Exactly the same issues to the letter. Did you ever get it resolved ?. |
Hi Rigman,
Cheers Dan, will probably get a new motor and see if that dos the job. |
scottohum21 Member Since: 08 Apr 2024 Location: Nottingham Posts: 1 ![]() ![]() |
John, I've read from some that it isn't very easy to remove the motor from the bracket. How was it for you? Did it separate ok for you? |
After a great deal of wailing and gnashing of teeth, bit the bullet and bought a new motor from range rover world with the intention of doing the job myself ( glad I didn't ). After getting under there and noting the condition of some of the bolts etc I took it to my local mechanic. Two things he mentioned - 1st he commented on the decent quality of the new motor ( none OEM ) 2nd he said it was an absolute b$**#~# to remove the old motor.
