Home > Technical > Need a scan tool, is this one any good please?
Gas-guzzler
United Kingdom 2007 Range Rover Sport TDV8 Sumatra Black
Has anyone used this scan tool and is it any good? If not could anyone suggest the one to go for at a reasonable price? Thanks.
Post #627313 Wed Oct 12 2022 10:22am
If you can get an autel ap200 in white, that would be better, and better value
works with smart phone
Post #627314 Wed Oct 12 2022 11:24am
Gas-guzzler
Oh that’s great thanks. I’ll have a look around see if I can get one.
Post #627322 Wed Oct 12 2022 2:15pm
Gas-guzzler
Thanks For your advice Andy. I bought the Autel AP200 from Amazon for £50. It quickly prompted me to investigate the rear left wheel speed sensor. After replacing that all my warning lights are extinguished and life is good again. It’s a great tool and looks really versatile with the availability of all car manufacturers that can be downloaded. Thanks again, great advice. Thumbs Up
Post #627429 Tue Oct 18 2022 1:35am
Glad it helped.
You do have to pay for other manufactures
Post #627430 Tue Oct 18 2022 5:32am
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
I have the iCarsoft and it has proved OK for diagnostics on my '59 plate L320, but it doesn't do programming.
Software updates are free, certainly at the moment anyway. It's not locked to a VIN number and will do oil service resets, EPB and battery monitor reset amongst others. It doesn't require a separate power supply, mobile phone/tablet, nor an internet data connection, so it will work out in the field
It can also read basic ODBII codes on other vehicles and has correctly diagnosed a failed crank shaft sensor on a Kia Rio, as well as inlet manifold baffles on a VW Passat.
Whilst I'm a competent mechanic on my 1985 Classic RR, I don't work on the L320, so it's all I need. I also have a very helpful indie!
But, if you want to do programming, then it's not for you.
Post #627445 Tue Oct 18 2022 2:14pm
Gas-guzzler
All good stuff. I’m still exploring the functionality of the AP200. Might take me a while. I did like the all in one convenience of the the icarsoft unit but the AP200 was so cheap in comparison it was that that won the decision. Thanks
Post #627457 Wed Oct 19 2022 12:47am
