![]() | Home > Technical > EPB repair path |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 210 ![]() ![]() ![]() |
So looked at various and many threads on EPB faults.
The battery is good . Its showing over 12.30 and 14v engine running.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1860 ![]() ![]() |
That's low, a fully charged battery should 12.7 or above. 2023 P440e SE Dynamic on order -cancelled
Ok I'll check this , but I haverun the car back and forth with it showing 14v and above and its not doing much difference for brake function. |
Testing wires with engine running and showing 14v at the dash with GAP IId connected. The wires on the park sw. plug connected are Y 6.33v, YB 10.95v , YG 6.47v, and Red 5.5mv. Earth black 0.0 ohms.
Sorry missed out another Red wire showing 8.16v |
Sorry missed out another Red wire showing 8.16v .
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Well a quick search on disco3 for that fault code U2002-01 suggests you need a new dash park brake switch !
£40 on eBay
I reckon the previous voltages are from a can bus so will be lower.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
£40.00 on fleabay £30.00 from a dealer. |
Aha , seems that the red wire I found earlier was on MV.,(see earlier thread) was the culprit , it was the only one showing open circuit. Spotted a white spot further off the plug about 5 inches from the plug and yes corrosion, soldered and reconnected, hand brake working ......Get On ! Ordered some heat shrink to protect the joint and bingo , fingers crossed. |
