Home > Technical > This has happened twice now |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Perfectly common. Most threads on here have been about dicy launches at a roundabout. Some have said it can be mapped out and equally others put the gears to manual and stick it in first/get going/then put it into drive.
Mon Oct 03 2022 3:49pm |
AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 119 |
Oh ok thanks, I panicked for a moment. If others have experienced this then I guess ok, just a little edgy when you want to pull off and out your foot down and the 2 sec delay (it’s actually probably a nano second but it feels longer ) |
Mon Oct 03 2022 4:03pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Ah, the suicide pause! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Mon Oct 03 2022 4:23pm |
Mon Oct 03 2022 4:31pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
It appears to be the way that Land Rover have mapped/calibrated the throttle / gearbox relationship along with setting off in 2nd gear. "They all do that, sir!" applies.
Mon Oct 03 2022 9:27pm |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 |
I don’t think the suicide pause happens when the car is in sport mode. |
Mon Oct 03 2022 9:54pm |
Good reading - thanks as always guys
Mon Oct 03 2022 10:27pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 487 |
How does my 2011 not do this? Are you driving with both feet? At a complete stop, I go brake to accelerator and the car rockets off. The transmission definitely goes into first when I come to a complete stop. Only at roundabouts where I quickly slow down then try to accelerate does it seem to bog down in the wrong gear, but no delay on the accelerator. Maybe it’s a RHD thing?
Tue Oct 04 2022 5:22am |
Our old Audi A6 did this and it had a CVT box. Once going though it was fine. I don’t think it’s an exclusive RRS issue though. 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Oct 04 2022 7:49am |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 202 |
Sports mode or a remap cures this, it seems to be more drastic on the RRS than other autos I own. 2018 Telsa MS
Tue Oct 04 2022 12:24pm |
If yours goes in to first gear every time you stop then it's definitely not a standard set up. They are set up to start in second gear when in drive and no special programmes selected. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Oct 04 2022 4:06pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
I get this lag when pulling away at roundabouts and busy junctions so it has been a habit to slide it into sport mode just before the junction as I believe that it tends to select 1st gear rather than the programmed 2nd for starting. Once moving you can slide it back into drive. Robin
Wed Oct 05 2022 8:13am |
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 126 |
Turning out of our Close on a blind bend with this ever present "lag" causes me some concern on most occasions, from now on I'll select sport mode to set off |
Wed Oct 05 2022 4:15pm |
So everyone’s car with a six speed transmission only shifts four times?
Wed Oct 05 2022 7:07pm |
