Home > Technical > something or nothing with air temp sensor
savi18
New Zealand
Hi Team,
First of all 2009 TdV6d is running great with no problems what so ever with No EML on, however every now again i check to see if any codes have been logged in systems and they have P0100-36/ P010-17/ P045C-00 PLEASE SEE PHOTOS, Also in photo you can see Air Flow Rate around 16.970 g/s and Also intake Air Temp 25 degrees C and both readings are in the red, have tried brand new MAF sensor and readings are almost identical and still in red, last year had the EGRs removed and mapped out and ECU remapped and butterfly valve removed also to increase power and fuel economy for which it did on both, is it best just to leave it as EML is not on and running great, its just the items in red is a bit of a worry. Cheers
SORRY THE PHOTOS ARE SIDEWAYS, COULD NOT GET THEM TO UPLOAD CORRECTLY.
Post #626919 Wed Sep 28 2022 1:34am
The colour maybe due to limit set within the tool
Post #626928 Wed Sep 28 2022 2:57pm
savi18
New Zealand
Thanks Andy, Can anyone give what approx values should be on 2.7tdv6 the g/s is around 17 to 19 on tickover and intake air temp at 25c or 77f which i think would be the ambient temp anyway.
Post #626949 Wed Sep 28 2022 11:14pm
savi18
New Zealand
Is it possible someone can check there MAF readings this weekend and post results, all i want to know is what yours is, mine is 17 to 18 g/s on tickover(engine warm), have fitted new MAF sensor and readings almost the same. 2009 2.7tdv6, Cheers
Post #626980 Fri Sep 30 2022 3:46am
I’m getting 18 to 19 g/s on cold start
As you say air temp is approx ambient temp. Maybe higher
Post #626987 Fri Sep 30 2022 2:23pm
savi18
New Zealand
Thankyou Andy
Post #627085 Mon Oct 03 2022 4:12am
