Home > General (L494) > Transfer box part number help.. |
Nick900 Member Since: 11 Mar 2022 Location: Kent Posts: 76 |
Really sorry you are going through this.
Wed Sep 21 2022 12:20pm |
WW88 Member Since: 02 Jun 2018 Location: Northamptonshire Posts: 12 |
It’s been such a pain!
Fri Sep 23 2022 6:29am |
From the way you describe the noise it sounds like it could be a wheel bearing. |
Sun Sep 25 2022 4:30pm |
That’s what I initially thought, but it rises with rpm around 2000, in each gear. & gets worse when hot. So I’m leaning more towards it being diff or potentially gearbox, I’ll see if I can upload a video. |
Tue Sep 27 2022 7:12am |
Worse when hot still suggests wheel bearing. If you can I would jack all four corners up and spin the wheels to check or just take to Kwik Fit |
Tue Sep 27 2022 10:47am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Rear diffs are very common for failing... |
Tue Sep 27 2022 11:59am |
RRS4ED Member Since: 05 Feb 2021 Location: Yorkshire Posts: 37 |
I have also recently bought new to me RRS, has exact same issue and very well maintained and it had a new new dif when it was 6 months old and another one 2021 cant remember if they are both rear.
Mon Oct 03 2022 3:47pm |
Noise has got a lot worse recently, definitely rpm related, so noticeable in manual mode. Almost like a knocking noise noise, with huge rumbling on deceleration & cyclic rumble when cruising, especially in lower gears. Noise isn’t present in neutral.
Fri Oct 14 2022 7:26pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
I had the similar issue on my L320 which turned out to be the front diff. Once changed the car was so much quieter. I’m told the RRS1 & disco 3 are quite hard on their diffs. So not sure if this fault would carry across to your 494. But I just thought I’d mention it. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sat Oct 15 2022 5:53am |
I’m just unsure on whether diff noise would relate more to road noise as opposed to rpm, but I could be totally wrong? |
Sat Oct 15 2022 2:26pm |
Update to this, noise disappears when nudged into neutral.. |
Wed Oct 19 2022 2:59pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Could be the propshaft connecting the back of the transfer box to the rear diff. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Oct 19 2022 3:36pm |
Just an update on this, it’s looking like it’s the torque converter, it’s being done first week of January, so will update if it solves the issue.. |
Sun Dec 04 2022 11:40am |
Interesting, looking forward to out come. |
Mon Dec 12 2022 3:39pm |
