Home > Technical > What’s the trigger / bottom on the gear leaver
AIJ 615
Hi guys
Range Rover sport Auto HSE 2010
What’s the trigger for on the gear stick. What does it do - can’t find it mentioned in the manual ?
Alan
Post #626713 Mon Sep 19 2022 7:47pm
Are you referring to the release button to shift the gearstick out of park/reverse etc.? only you shouldn't be able to move the stick from park unless you press it in, all works in conjunction with the transmission interlock solenoid I believe.
Post #626714 Mon Sep 19 2022 9:13pm
AIJ 615
Thanks Colin
I’ve only had RRS since weekend and always used the trigger when I change gears anyway so that’s cool - thank you
Al
Post #626736 Tue Sep 20 2022 6:38pm
Post #626746 Tue Sep 20 2022 10:16pm
AIJ 615
Perfect, appreciate this - thank you
Al
Post #626747 Wed Sep 21 2022 2:08am
It doesn't need to be pressed when moving between D and N
Post #626755 Wed Sep 21 2022 11:25am
