Home > In Car Electronics > Landrover logo on constantly ? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4981 |
Try a different screensaver, choice of five on mine, I believe earlier cars had three or possibly four, although I generally just leave mine on the home menu screen.
Mon Sep 19 2022 9:17pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
I just leave mine on the 4x4 screen as I use the lower/raise function quite often to let the dogs in/out. 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Sep 20 2022 6:44am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8986 |
The facelift L320 doesn't seem to allow you to leave the screen on 4x4. I used to do the same in my old 2008 TDV8 but can't on my 2012 SDV6 - it reverts to the "home" screen every time it's switched on. 2012 SDV6 - it's missing a couple of cylinders
Tue Sep 20 2022 8:14am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4962 |
2010 would have a denso unit.
Tue Sep 20 2022 11:37am |
AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 119 |
Interesting, thanks guys
Tue Sep 20 2022 6:40pm |
No screen saver. If only ! |
Tue Sep 20 2022 6:53pm |
I certainly have screen savers on mine not sure about a 2010 car though as I know it's a different infotainment interface. Try touching Setup, Screen, Screen saver in the menu. Mine brings me to this screen five choices 1 blank and four images two of which are pictures which are taken from sales brochure I think. If you turn screen timeout off it stays on the set screen until you either touch another button or switch the car off. I did put a shortcut to the 4x4 screen on the home menu screen so one touch of the button brings up the screen and it stays on till switch the car off, then as previously mentioned always defaults to home menu when car switched on again.
Tue Sep 20 2022 9:15pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 480 |
Completely different in 2010/2011 models, no such option I’ve seen and I’ve been through all the menus. I either use 4x4 info or turn the screen off. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Sep 21 2022 4:30am |
Thanks for confirming, 👍
Wed Sep 21 2022 5:52am |
