Home > Technical > 2012 Range Rover Overfinch LED Running lights
The Range Rover
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
Hi All
I have a 2012 Range Rover Sport Overfinch which has LED Bumper lights, but the Offside cluster has 2 LEDs not working, Can this be repaired, or what is the replacement, I cannot fir the life of me work out which model they are from!
Any help much appreciated!
Post #626633 Thu Sep 15 2022 11:21am
If it is the same bumper as mine, then it is the O/F GTS body kit, you could try O/F but the DRL's alone were sold as a pair at the absolutely ridiculous price of £1000.00 + yes that's the right number of zeros. Rolling with laughter If you google Nolden DRL's I think you will find they are the original manufacturer of the lights, although I think that particular lamp (M169) may be obsolete/discontinued now although (ML-030) may be a alternative replacement would need to measure the physical size. Price is probably a quarter of O/F's price as well.
https://www.noldengmbh.de/files/daten/down...%20ENG.pdf pages 8-11
Obviously be worth trying to repair the old one, the actual Led's/bulbs or whatever the correct name is for them were Philips LXML-PWN2 I think, could Google that number and see what it throws up.
Post #626648 Thu Sep 15 2022 10:13pm
