175/ 80 R19 spare tyre pressure
Hi All,
Been checking the tyre pressure of the spare and note on the side it says 60psi. Can I check if this is correct? 60psi seems quite high given the actual road wheels are around 36psi.
As always, thanks in advance for your help & advice.
Thu Sep 08 2022 3:42pm
scarey
60psi is correct...its to do with the smaller width and the weight it has to contend with...
i believe the current trend in new cycle tyres is around the same psi..
Thu Sep 08 2022 5:21pm
Cymru001
Thanks for the response.
I know cyclists do use higher pressures, particularly those involved in competitive road racing, as it reduces the amount of tyre in contact with the road as, as a result, reduces drag; but 60psi just seemed a bit high when I read it. I got to 44psi and bottled it!!!
Thu Sep 08 2022 7:05pm
Lindab
I put 60psi into my bike tyres using my electric pump, but stood well back until the pump switched offRange Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
