![]() | Home > Maintenance & Modifications > Engine System fault |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
hi
hi
Hightimo Member Since: 08 Jan 2022 Location: Liverpool Posts: 77 ![]() ![]() ![]() |
I had similar problem with my tdv8 about 6 mtgs after replacing both turbos . It ended up with the os turbo coming off again as it was carboned up solid causing the vanes inside not to move - you can check from underneath- the actuators should move freely- if not there’s a problem and it will throw warning on and restrict performance. The actuators go through a cycle on initial start up to locate the vanes if this cycle fails the warning will pop up just after start up. |
