Home > Maintenance & Modifications > Diagnostic Toll or Software
Rev1Richie
United Kingdom 2005 Range Rover Sport Supercharged Chawton White
Hi Guys, i need to have a better way of trouble shooting problems than just a code reader, Now on my BMW i had some software for my laptop which enabled me to do a vast amount of interegation and mods.
Now for this RRS of mine is the same available or should i get a diag Tool , about £500 and if this is the prefered route , anybody got any recom's
What i need yo be able to do is for it to tell me why it reduced the performance
Many thanks
Rich
Post #626294 Fri Aug 26 2022 7:55pm
NoExpert
Most diagnostics tools will give you a code. Even JLR-SDD gives you a code and then you go through the diagnostics flow chart, unless you already think you know what it is.
Mine popped restricted performance a little bit ago. Hooked up to JLR-SDD and it said MAP sensor was out of range. Well, knowing the little bit I do about these cars I immediately looked at my intake manifolds, sure enough one was cracked and leaking.
Have you downloaded the workshop manuals for your car? With the code and the workshop manual you can get through most issues. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #626303 Sat Aug 27 2022 2:46pm
Rev1Richie
Hi mate, thanks for that, food for thought
The JLR-SDD its software , goes on a laptop? how does it hook up to the car, i'm seeing a lot of V. Expensive cables, is it one of these?
Regards
Rich
Post #626319 Sun Aug 28 2022 11:08am
If you want value for money.
See if you can get an autel ap200 white
Post #626321 Sun Aug 28 2022 5:28pm
Rev1Richie
Andy do you rate this box then...
Rich
Post #631191 Mon Feb 27 2023 11:53am
Well if you compare a generic Ebay/amazon £25 diag tool with an AP200 @£60 then it is an amazing bit of kit.
This is because it will program keys, calibrate the suspension etc.
Ok, it's not the fastest thing I have used, but for the money.....
The Gap IID is an amazing bit of kit, with great support. But it costs £500
It's almost worth getting the AP200 (white) first an seeing what you think, I can be used on other cars too.
https://www.disco3.co.uk/forum/autel-bluet...5-150.html
Post #631222 Mon Feb 27 2023 7:00pm
ShouldHaveStuckWithAudi
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Sorry to revive an old thread but seems to be very relevant as i have just got a new (to me) MY13 RRS and was pretty sure the Maxi AP200 (the white one) could reprogramme keys but i've checked and none of the hot functions seem to be correct, even though i've used the 'verify keys' and seems to work (so it's clearly got the smarts to be able to do something with keys). BTW, in the above screenshot, the 'immobilisaztion' function doesn't seem to work, so am wondering if that's the way it should have worked...
@Andy K - have you managed to programme a key with the AP200?
Post #644124 Sat Sep 07 2024 6:09pm
Not seen one your year done.
Post #644127 Sat Sep 07 2024 8:22pm
