Home > General (L494) > Buying a 2015 SVR anything I should look for ? |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 |
Rear brake lines? And test the Aircon! |
Fri Aug 26 2022 9:41pm |
Ridgebacks Member Since: 26 Aug 2013 Location: Ipswich Posts: 49 |
corrosion on brake pipes or callipers ? |
Fri Aug 26 2022 10:38pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
Check the coolant crossover pipe. Not sure exactly where they are but I remember hearing about them being 2 pieces that eventually fail, leading to catastrophic engine failure with out any warning. Also, on my 2016 SVR the front ACE bar was leaking and needed replacing. 2016 RRS SVR Estoril Blue
Sat Aug 27 2022 8:24pm |
Rear brake lines…apparently very common and susceptible to rusting hence failure. |
Sat Aug 27 2022 10:41pm |
MBSVR Member Since: 27 Jun 2020 Location: Bedfordshire Posts: 26 |
look for nearby petrol stations 2020 Range Rover Sport SVR 5.0L V8 Supercharged |
Sun Aug 28 2022 4:55am |
Many thanks for the replies 2016 SVR |
Mon Aug 29 2022 11:47am |
I’ve got a 2020 5.0 mustang I know where they are 2016 SVR |
Mon Aug 29 2022 11:48am |
