Home > Technical > Recommended Engine Oil |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
https://www.advancedfactors.co.uk/service-...-198-c.asp 2012 SDV6 - it's missing a couple of cylinders
Sat Aug 27 2022 4:16pm |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 225 |
Think i might start doing my own servicing now with the costs over £350 from Indys for oil and a few filters! |
Sat Aug 27 2022 5:44pm |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 |
Cheers for that Is the following link the correct kit for my car https://www.advancedfactors.co.uk/kit106a-...0503-p.asp Also do you know what size socket I would need for the oil filter? Need to order one as im going to attempt to service the car myself RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
Sat Aug 27 2022 9:39pm |
Thats what im planning to do, wish me luck RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
Sat Aug 27 2022 9:40pm |
I dont think you can go wrong with the oil and filters, Just check diesel filter, I hd a mechanic not tighten mine up a few years ago and lost 1/4 of a tank of diesel because of this so maybe that filter needs double checking its in correct, I mean if a qualified mechanic can make the mistake then maybe its not an easy diy job. |
Sat Aug 27 2022 10:08pm |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 202 |
Very easy to crush or break the seal on the fuel filter 2015 L494 SDV6 3.0 HSE Dynamic
Sat Aug 27 2022 10:23pm |
Anyone know the socket size to remove the oil filter? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Sun Aug 28 2022 10:11pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
https://www.fullfatrr.com/forum/topic2393.html
Tue Aug 30 2022 10:43am |
