Home > Maintenance & Modifications > Releasing stuck parking break (electronic)
pomistea
Ireland 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
My parking brake started making a horrible squealing sound yesterday.
After trying various things, it released after I raised the suspension.
It is now stuck again and nothing is releasing it.
I tried the release loop that is hidden under the handbrake button.
It travels up for about an inch then stops. I pulled it pretty much as hard as I could and it goes no further and doesn't release the brake.
I really need the care badly today.
Is it possible to release at the rear wheels?
Post #626035 Wed Aug 10 2022 8:11am
It needs pulling really hard.
So hard you think it will break
Post #626036 Wed Aug 10 2022 8:53am
pomistea
And it won't break?
What did you pull it with?
Post #626037 Wed Aug 10 2022 9:09am
I believe ppl use the jack handle from the boot
Don’t know if you have room on that model
Post #626038 Wed Aug 10 2022 9:28am
pomistea
Do you hold down the brake button for 3 seconds while turning off the engine to stop the auto brake engaging?
Post #626039 Wed Aug 10 2022 9:33am
That’s when it’s working
And generally for the manual transmission discovery
Post #626041 Wed Aug 10 2022 9:45am
pomistea
Okay, first, thanks a million, Andy.
Couldn't see how the jack handle could catch the loop but I used it to twist the coat hanger around to make a handle.
I pulled as hard as I could, didn't feel any movement, the coat hanger eventually bent and came flying up, buttttt....brake released!
I tested and yes, with it in P, hold down the brake button (disengage), turn off engine, continue holding brake button down for 3 seconds and it doesn't re-engage automatically.
Post #626042 Wed Aug 10 2022 10:01am
pomistea
New problem. These screws won’t catch at all.
Post #626044 Wed Aug 10 2022 10:59am
Sorry I'm not familiar with that model year, so can't help with your screws.
I thought once you had pulled the manual release, then a light or message would be stuck on the dash and a mechanic would have to do cleaver things to get it to work again. (diagnostic tool and/or under the rear of the car) and of course fix the reason why it was stuck on in the first place
Post #626046 Wed Aug 10 2022 11:12am
pomistea
But I’m still holding down the handbrake button every time I stop the car as I’m not sure if auto mode is off or not.
Post #626050 Wed Aug 10 2022 12:57pm
You de-activate the auto apply park brake mode permanently via the CCF files.
Post #626056 Wed Aug 10 2022 8:16pm
