![]() | Home > Maintenance & Modifications > Egr delete and remap |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 49 ![]() ![]() |
Yes. contact Bell Auto Services in the UK. The patch is sent electronically to the IID tool and you apply it yourself. Pete
Sween23 Member Since: 11 Jan 2022 Location: Lancashire Posts: 10 ![]() ![]() ![]() |
Brilliant, thanks Pete |
Yankee Doodle Member Since: 03 Aug 2022 Location: Reading Posts: 17 ![]() ![]() ![]() |
I was going to do this myself, does the remap get rid of the engine management light after blanking off the EGR? |
3hcp Member Since: 04 Nov 2021 Location: Devon Posts: 79 ![]() ![]() |
You should be able to get the egr electronically mapped out so it stays closed. Improves drive ability and throttle response as the engine is getting clean air not used fumes. 2015 RRS DIESEL HYBRID |
Apologies if this comes up twice, how does this affect the emissions for the MOT? RRS SDV6 HSE Black Edition + |
Doesn’t 2015 RRS DIESEL HYBRID |
Great, thanks bud RRS SDV6 HSE Black Edition + |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
you need to leave the EGR pipework in place (just insert the shims between the pipes and EGR/manifold so that at a glance they haven't been deleted. it's a MOT fail and illegal to tamper with emission equipment, not to mention problems with your insurer (and they may remove the engine cover if they have to inspect it, unlike the MOT tester who can't). |
Yes if you tell Pete that you'v blanked the EGR and the EML light is on. He'll code it out. Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Use a company that actually maps out the egr valve so it stays shut that way you don’t need to blank anything, not just someone who turns off the engine light monitoring. 2015 RRS DIESEL HYBRID |
Bell Auto Services do exactly that Visitor from fullfatrr.com
thanks RRS SDV6 HSE Black Edition + |
