![]() | Home > Technical > Couple of Minor Issues RRS 55 plate. |
Yes, the RRS is a whole other animal from the RR.
Brian Considine Member Since: 26 Mar 2022 Location: SE UK Posts: 93 ![]() ![]() |
Thanks, looks like I may need to find a good Indy in my area (East Kent) to switch off the cornering lights.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
So the cornering lights only come in while Corning or on all the time ? Just take the bulbs out.
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 315 ![]() ![]() ![]() |
The cornering lights never worked on mine so I’ve installed Led bulbs and rewired as DRL’s. Steve
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 218 ![]() ![]() ![]() |
Try Ansells Service Centre in Lydd Used them a few times, Jason and Dan are ex JLR so they know what they're doing and reasonable for price too 2015 L494 SDV6 3.0 HSE Loire Blue 2006 L320 4.2 Supercharged 2009 BMW X5 M-Sport - Gone 2007 L320 2.7TDV6 SE Buckingham Blue - Gone 2011 Jaguar XFS 3.0V6 Diesel - Gone 2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone 2008 BMW X5 M-Sport - Gone 2005 Audi A6 3.2V6 Quattro S-Line - Gone |
Cornering lights should come on with turn signals or while driving under a certain speed coupled with the steering wheel turned a certain amount. I believe driver side comes on later in steering wheel turn than passenger side. I like mine, but I tend to drive through small villages and on country roads where lighting can be few and far between. There have been a few instances where my car lights are the only lights visible in any direction as far as I can see. It’s almost a light show with the adaptive headlights, cornering lights and auto high beams doing their thing.
Double checked the cornering lights & they only seem to work at low speeds so I can live with that. Thanks for the link - looks like a couple of relays & a little time to fit. |
Thanks, pity they are so far from a station (if I have to leave the car). |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
cornering lights on my 2006 plate sport comes on when I do less than 20-30mph
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 273 ![]() |
For the seat issue there switch panel is just screwed onto the plastic seat valance , there's 2 pins at the top that pop out then its 4/5 torx screws holding the seat button controller and its just connected with a long connector - just double check no wires are loose on it - you can buy the seat button controllers quite cheap from ebay also. |
Thanks - I'll have a look. |
