Home > General (L494) > Front ACE pipe 'weeping', MY2015 L494
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Looks like LR044565 leaking in 2 places. Has anyone had any experience fitting these? Guy Salmon spotted it during the timing belt service want £450 for the privilege. L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #625435 Fri Jul 15 2022 8:46am
Eaters
I'm not sure if this is a direct comparison with the 320 but a couple of years ago my Indie spotted a leak in mine. When I asked what to do about it he said leave it for now as it was very minor. So 2 years later and still no serous issues and the suspension still all works as it should.
Also just noticed this which may be a red herring as I'm not sure they are compatible with your 494 but the price from Guy Salmon doesn't look too bad based on this limited research
https://www.lrparts.net/lr015144-front-ace...rover.html Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #625541 Wed Jul 20 2022 5:28pm
MaxDog197
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
I have a 'weep' on mine. (62MY 320 Autobiog) as the pipes are difficult to obtain currently (back order) I'm happy to leave it weeping for now.
Post #644727 Mon Oct 14 2024 2:43pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Re: Front ACE pipe 'weeping', MY2015 L494
The part no. you have is for a 4.4 SDV8 vehicle as opposed to a 3.0 SDV6 (your profile says a SDV6 494). I've replaced this on my 3.0 L494 as it was misting only for the new one to do exactly the same. It seems they mist where the high pressure hose is crimped to the alloy unions. Couldn't be bothered to chuck more money away and left it alone - that was over 100K miles ago and it's never caused a problem with low ACE fluid.
SDV6 - https://parts.jaguarlandroverclassic.com/p...and-rover/
SDV8 - https://parts.jaguarlandroverclassic.com/p...and-rover/
Have a look at it, and it'll probably be a very fine mist at either end of the flexible pipe, then make up your mind. Incidentally the part No. for the SDV8 is £90 dearer than the SDV6, so that makes their labour quite high for a simple job.
Post #644728 Mon Oct 14 2024 3:24pm
