![]() | Home > In Car Electronics > RR SPORT ELECTRIC WINDOWS |
Mantaraman Member Since: 04 Jul 2018 Location: St Albans Posts: 16 ![]() ![]() ![]() |
RR SPORT. 2007. L320.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
usually its the wiring to the door (where it hinges)
Andy K, thanks for the tip. Bought a new (ebay cheap deal) switch but it didn't work. Eventually tried pushing/pulling the buttons and got 3 windows working on the original switch, n/s rear not. Removed the door card, disconnected its individual switch, re-plugged it and the window then worked. 2 days later, all windows are still working. Don't know if there's an ECU for the windows but - with all windows closed - pulling up all 4 buttons on the master switch might have been the answer. Hope you don't need it but this might be worth a try if you get into the same situation. |
