Home > General (L494) > Boot Right Hand Fuse box - Is mine different
Karlp606
So I’m just checking my fuses as I think the sub issue could just be simply a fuse.
So I pulled the rear cover from luggage area to access the fuse box where the aux battery is but my fuse layout seems completely different to anything else I can see on the internet!
Mines a 2013 HSE dynamic but all other fuse layouts I’ve seen they don’t seem to match to my layout??
https://www.rangerovers.net/threads/fuse-box-diagram.351562/
This is all I can find?
Sorry forgot to add this is my fuse box
Post #625302 Sat Jul 09 2022 8:32am
jimbg
You need to find one for the early L494's. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #625303 Sat Jul 09 2022 10:38am
Karlp606
Struggling! :/
Post #625308 Sat Jul 09 2022 2:41pm
Not sure which year these illustrations apply to, but are you sure there is not a second lower fuse box in the bottom lower r/h corner?
Post #625314 Sat Jul 09 2022 11:54pm
Karlp606
Thanks @colb:)
Sorry do you mean in the luggage compartment or the glove box fuse area?
The picture shows the glovebox one
Post #625315 Sun Jul 10 2022 7:14am
The top right of the lower illustration is the boot space, ringed item is the lower fuse box.
Post #625316 Sun Jul 10 2022 7:37am
Karlp606
Ah great thanks will double check this morning 👍🏻
Post #625317 Sun Jul 10 2022 7:55am
Karlp606
So I found the lower fuse board! It’s the next panel along where tow bar buttons are installed.
Pulled each fuse all good - upon starting the car the bass sounds a lot better so seems the sub is kicking in better but the audio settings are just still stuck on Stereo - I still can’t select the 3 other options for my meridian 825w system.
I’m starting to think it could be software issue now as all audio is working, dab/iPhone etc I just can’t select the 3 audio options. I can press on them and I get the selection beep but It won’t shift the selection from stereo.
I’m stumped!
Post #625322 Sun Jul 10 2022 1:29pm
