![]() | Home > Faults & Fixes > Brake Booster vacuum pipe |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Good spot. There is also coolant pipe, which comes out from under engine cover at the front which can suffer from the same. The cut out needs enlarging really. |
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Hi thanks for reply yea I just checked around the coolant pipe you mentioned and luckily my engine cover cut out around it is large enough it’s not touching the pipe thanks.Im sure car manufacturers notice these issues but ignore them to deliberately increase there parts sales !!!!! |
