Home > General (L494) > Park Assist retrofit |
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 87 |
Short answer is yes it can be retrofitted, but you will need an IID Tool as well as four new sensors and two looms. This will then give you both parallel parking and perpendicular parking capability as they are two different programs
Mon Jun 27 2022 11:53am |
Nick900 Member Since: 11 Mar 2022 Location: Kent Posts: 76 |
Thanks, that is really helpful and I would appreciate some more advice.
Mon Jun 27 2022 1:12pm |
Searched 'park assist' and could not find anything regarding retrofitting. Read through 5 pages of old posts and nothing seemed to relate to it?
Mon Jun 27 2022 1:44pm |
Yes the whole original looms will need to be replaced as they do not have the end connectors for the side facing sensors. The part number for the new sensors is LR038533 rear and LR024299 front
Mon Jun 27 2022 7:24pm |
Would you happen to know the part numbers for the wiring looms?
Mon Jun 27 2022 11:52pm |
LR053995 is the part number for the rear wiring loom and I know that as that is the one I had to purchase.
Tue Jun 28 2022 9:00am |
I have tried LR Parts and emailed Duckworths too.
Tue Jun 28 2022 11:21am |
Yes I remember that comment coming from my local Land Rover dealer when I was trying to select the correct part number to buy.
Tue Jun 28 2022 2:35pm |
Thanks to Heremyjill everything is up and running now and working perfectly. Should assist my poor parking from kerning the 23" wheels.
Wed Sep 28 2022 4:01pm |
Gixxar Member Since: 27 May 2020 Location: Aylesbury Posts: 8 |
Could you tell me exactly what you done? I have the parallel parking but not the perpendicular parking.
Thu Jan 26 2023 11:03pm |
Could you tell me exactly what you done? I have the parallel parking but not the perpendicular parking. TIA Lee |
If you have the parallel but not perpendicular then the first question is do you have the sensors in the sides of the front and rear bumper?
Thu Jan 26 2023 11:43pm |
Hi Nick,
Fri Jan 27 2023 12:22am |
Hi Lee,
Fri Jan 27 2023 9:01am |
