![]() | Home > General > wiper blade length |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
I'm fairly sure the fronts are both 22"s, and the rear is 16". Barrie.
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
brilliant i wasn't sure, the bosch twin pack says 22 & 21. so both 22 thank you very much |
I would strongly recommend a double-check. Google searches vary from 22/20, 22/21, and 22/22. I have 2x22s on my 2005.
I've checked the book too but like you say nothing, just measured mine and there both 22 so i will stick with that |
YEAH SPEC is 22 / 21, however a lot of people just fit 2 22" |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 263 ![]() ![]() |
Mine probably need replacing for the first time in my ownership.
I have Bosch Retro Flat Blades. Effective and efficient. Not noisy. Barrie.
So i fitted the bosch aero and so far so good |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 247 ![]() ![]() |
I found that the Bosch ones were quite noisy, even from new, so replaced them with Valeo Silencio. Really pleased with them. |
