Home > General (L494) > Rear diff oil leak
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Rear diff oil leak
So had my car MOTd today and it came back with an advisory, oil leak, but not excessive rear (diff). I have no oil on the floor of garage and to be honest can’t see any form of moisture or oil leak from under the car. Should I be worried?
Post #624892 Mon Jun 20 2022 5:46pm
Johnrrs
I have the warranty direct warranty on the car and it does say that oil seals are covered. See section C on the photo. Anyone else had this issue?
Post #624893 Mon Jun 20 2022 6:21pm
Johnrrs
Don’t know why photo is upside down. Can’t turn it round
Post #624895 Mon Jun 20 2022 6:24pm
jimbg
Because you were holding the iPhone upside down! Rolling with laughter
This site does not read the non standard data stored in the image regarding the phone orientation. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #624899 Mon Jun 20 2022 9:12pm
Johnrrs
It’s the right way up on the iPad where I sent it from
Post #624901 Mon Jun 20 2022 9:44pm
jimbg
Of course it is, the non standard orientation info stored in the photo by Apple will be understood by any Apple device.
There are dozens of posts on the forum that have fallen foul of this.
The only way to avoid it in future is to hold any Apple device in the correct orientation or use an app to correct it. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #624906 Tue Jun 21 2022 7:51am
Skyline
Re: Rear diff oil leak
Had this on mine - is a known issue and was covered by LR aftermarker warranty. Hope you get it sorted.
P MY23, 3.0 P440e PHEV AB, Carparthian Grey, Deep Garnett interior
MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian
Post #624907 Tue Jun 21 2022 9:36am
In your gallery, select the image and then immediately below the image is a button to "crop and rotate". 2012 SDV6 - it's missing a couple of cylinders
Post #624912 Tue Jun 21 2022 9:50am
it's the infamous rear diff pinion seal leak - there is a recall for that fix, it should have been done under LR warranty.
See here: https://www.rrsport.co.uk/forum/topic53164.html
Even a slight leak can cause the bearings to run dry and then you get the dreaded whine, which means a whole new rear diff. Hopefully not the case with yours. --
Post #624913 Tue Jun 21 2022 10:33am
Johnrrs
So I had a look under car today and found what could be the cause of the leak. It looks like some sort of nipple with a square hole in it. It looks like it can be removed or tightened up and no doubt will have a seal of some sort. What do you guys think?
Post #624929 Tue Jun 21 2022 6:49pm
Johnrrs
I have wiped the moisture away so on some photos looks dry ish
Post #624930 Tue Jun 21 2022 6:54pm
Nick900
It is the drain plug. Changed my diff oil last week. To resolve just buy a new one. You will need to slacken the fill plug first do this before you do anything else in case you can't remove it. Otherwise messing with the drain plug you loose oil undoing then cannot refill. Takes about 0.8l.
Nick
Post #624937 Tue Jun 21 2022 8:21pm
Johnrrs
I’ve had a sheet of cardboard under the car now for 1 day with not a drop of fluid on it. When I take the car out over the weekend I’ll keep the sheet under it to see if it leaks when engine is warm.
Post #624959 Wed Jun 22 2022 9:12pm
Nick900
Check how tight it is, should be 30NM
Post #624964 Thu Jun 23 2022 8:47am
Johnrrs
So I’ve pulled the car out of the garage and raised it up on the air suspension to get a better look. I know it’s not a good idea to get under the car in case it comes down by itself but I was very quick…..So the leak looks to me like it’s coming from the shaft that goes in then I assume the fuel is tracking down to lowest pint that is the drain plug. Photos attached. I’m getting worried now. I’m hoping this is covered with my WD warranty. I’m going to contact JAS tomorrow to see if it’s something that would be covered by a warranty.
Post #624974 Thu Jun 23 2022 8:59pm
