Home > Faults & Fixes > Yellow suspension light
Mccolganm4
Ive had the light coming on randomly for a wee while but it usually clears once the car has been left for a few minutes. Finally hooked the GAP up and read the codes. Screen shot above.
Does this refer to the air compressor pressure sensor or the Anti roll bar pressure sensor? Ive had a look at the plugs and wiring in the passengers wheel arch and it all looks good in there.
Post #624279 Sun May 15 2022 2:28pm
Mccolganm4
Antone got any ideas? The light is back on again today
Post #624344 Thu May 19 2022 12:23pm
Mccolganm4
Ok, this fault has become permanent now. It's more annoying than anything but would really like to get it sorted. Any sort of advice would be much appreciated
Post #624661 Mon Jun 06 2022 5:39pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Not in the habit of posting negative replies (can't help with your problem) but just to reassure you your message is visible here! Neutral Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #624664 Mon Jun 06 2022 6:50pm
Disco_Mikey
Wiring issue
Had the same fault on my D3. Twice Laughing (Had a "temporary" repair that lasted for 2 years Laughing )
Post #624667 Mon Jun 06 2022 8:06pm
Mccolganm4
Cheers Mikey. I'm going to start with ripping the NSF arch liner out again and go from there. I'll update if I find anything
Post #624671 Mon Jun 06 2022 8:18pm
Disco_Mikey
That's the best place to start on a pre 07MY Thumbs Up
Post #624672 Mon Jun 06 2022 8:28pm
Mccolganm4
Had a look at this over the last few days. Checked wiring in the wheel arch and was all good. No sign of damage inside the wiring harness and the plugs were spotless. Booked into a local LR specialist who advised that is was the ACE system at fault and related to a pressure fault. They recon that starting to replace bits on the ACE system is like opening a can of worms and to be prepared for a potentially big bill. I now have the car back and plan on doing a fluid change and possibly the pressure sensor if that makes no difference. I'll let you know how it goes.
Post #624786 Tue Jun 14 2022 12:06pm
BJH1959
Good luck! And yes, please post how things go. Thumbs Up Barrie.
Post #624787 Tue Jun 14 2022 12:19pm
Mccolganm4
So fluid change made no difference other than it is now green instead of black! I have taken a punt on a cheap pressure sensor from eBay. Going to start soaking the sensor in WD40 for a week and have a go at getting it out.
Post #624801 Wed Jun 15 2022 9:01am
Mccolganm4
So I just noticed on my IID tool while clearing the code again after checking the plug at the sensor that my battery voltage with ignition on is 11.6v. surely that's low? I'm going to borrow the battery tester from work tomorrow and run a test on it.
So question is could the low battery be causing my problems?
Post #624816 Wed Jun 15 2022 6:46pm
Scrumpy
11.6v does seem low from what I've read in the past.
And yes, low battery voltage can throw up all sorts of electrical faults, so without diving any deeper than you already have, it would seem like a good place to investigate.
Reasonably cheap and easy to replace a battery, or repair it if it can with a CTech charger/conditioner or equivalent.
Hope that's all it is. Thumbs Up 2016 RRS SVR Estoril Blue
Post #624822 Wed Jun 15 2022 9:41pm
BJH1959
Yes, could be related to low battery. Fingers crossed. Barrie.
Post #624826 Thu Jun 16 2022 5:46am
Mccolganm4
Got the battery tester in the car ready to take home and my pressure sensor has been delivered today too. hopefully I'll be a happy lad in an hour or 2
Post #624832 Thu Jun 16 2022 3:49pm
Mccolganm4
Well the battery tested good on static test and load test. Got the sensor out, with a little help from a Ford oil filter removal tool, it routes round the ACE pipes quite well. Compared it to the eBay 1 and it was the same. Got it fitted, cleared the codes and fires her up. It's been 15 minutes idling and no leaks and no lights. Away to grab some food then take it for a run.
Post #624833 Thu Jun 16 2022 5:15pm
