Home > Maintenance & Modifications > Sun Visors L494 into L320 |
Umar Kamani Member Since: 08 Nov 2020 Location: slough Posts: 14 |
Have you tried to fit the XF handles? |
Sat May 21 2022 11:00am |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 |
Not yet no. the xf cream handles have the same part number as mine so my assumption is that the black are the same dimensionally |
Sun May 22 2022 6:29am |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 |
Nice mod to re trim the head lining have you thought about doing it in leather ? Iv redone my A pillars in leather will do the rest soon.
Sun May 22 2022 11:51am |
I'll retrim the pillars in alcantara. Any tips? I can't decide to dye or trim the headliner |
Sun May 22 2022 1:49pm |
What you have chosen is very difficult to work with as it bleeds threw a lot unless you have backed/lined material. Iv done a few P38s and D2s and used kits from martrim then switched to good old bay of E . The glue is the key.
Sun May 22 2022 2:31pm |
the Alcantara? does the glue leak through? I was worried about that as I need to get a low viscosity glue to adsorb into the roof liner. what glue do you recommend? do I need to remove the covering on the OE roof liner? |
Mon May 23 2022 9:29am |
