![]() | Home > General (L461) > Tow Bar Retrofit? |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Anyone know if there is a removable tow bar like previous models? I likely have a launch model coming which doesn’t have towing fitted.
ljw350 Member Since: 27 Aug 2014 Location: Norwich Posts: 36 ![]() ![]() |
I used these guys for my L494 and they might be able to help as believe these are the manufactures. Great service from them. £425 with LED light wiring. higher nose weight than most at 200k instead of 150kg and tow 3500kg.
Thank you.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1874 ![]() ![]() |
They have to practice on someones car. |
CJR Member Since: 10 Mar 2023 Location: Nottingham Posts: 3 ![]() ![]() |
Hi I am in the same boat, have a P510e Autobiography arriving in a few weeks, managed to get a cancelled order but couldn't add the tow bar, what has the dealer quoted you for retro fit of the deployable ?
RRSporter Member Since: 08 Nov 2012 Location: UK Posts: 61 ![]() |
I’m sure there will be. According to dealer deployable towbar is not available at build atm due to no stock, so don’t expect to order one for your dealer to fit any time soon…
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
It'll be way more time intensive retro-fitting the tow bar and associated electrics than it would be doing it during build. Add the fact that the dealer's charge hourly rates that would embarrass a barrister, and you have an expensive project, sadly. 2012 SDV6 - it's missing a couple of cylinders
Yup. Cost me about £3k to retrofit the deployable tow bar on my p440e AB. 😭 2022 P440e AB |
