Home > General > Parking sensors.
draiwer
Parking sensors.
Hi. 2010 RSS parking sensors are not working. All errors have been cleared and it is known that one rear sensor needs to be replaced. All cameras work, but the sensors do not work. What do you recommend?
Post #624082 Sun May 08 2022 11:38am
karlos01
Front parking aid will be parking sensor. Put it in reverse with ignition on only preferably with someone sat in the car with foot on the brakes. Listen to the sensors they will click. You’ll find you’ve got a dud one. Cheap and easy enough to replace as I’ve done myself.
Post #624087 Sun May 08 2022 12:51pm
draiwer
I know which sensor is broken but the question is why don't all the other sensors work?
Post #624092 Sun May 08 2022 3:32pm
karlos01
if one is not working then the electrical circuit will not be complete so that could cause the others not to work
Post #624094 Sun May 08 2022 4:14pm
One Sensor will knock out front and rear
Post #624096 Sun May 08 2022 5:29pm
draiwer
I wouldn't have believed that, but thanks for answering.
Post #624129 Mon May 09 2022 4:01pm
karlos01
it's fine some people don't know
RRS are here to test us 😅😅
Post #624142 Mon May 09 2022 6:22pm
