Home > Maintenance & Modifications > Gaskets etc
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Gaskets etc
2005 2.7 tdv6.
Where is the best place to get a top end gasket set including head gaskets and head bolts please?
I also need a full set of valve stem seals and a set of rocker bolts and washers.
Are there any other items on the engine worth swapping whilst the body is off?
Rough cost?
Many thanks.
Post #624038 Wed May 04 2022 9:10pm
you want to test glowplugs while head is off and replace them (right pain as they usually snap)
Head gaskets are shimmed custom to the engine bottom end. So note the number of notch's on the front of the gasket, and you want a replacement gasket the same thickness.
I got gasket set from ebay
Headbolts jgs4x4 or advanced factors. (prices seam to have doubled since I did mine)
Post #624040 Thu May 05 2022 11:12am
