Home > Faults & Fixes > rear door not locking
karlos01
hi folks I've searched through threads but can't find answer
I've got a 06 4.2 SC and when I lock with key fob rear door doesn't lock
I don't get a beep when I set alarm. I can lock it from inside and unlock with key fob.
door will not lock like the rest do when I drive down the road.
could the lock switch be faulty or could it just need a bit of lubricant?
don't really want to pull door apart to many times if I'm best to just get a new locking mechanism
thanks guys and girls for your information
Post #623980 Sun May 01 2022 2:41pm
riverblanche
sounds like the door actuator, have a search many threads about it, I have just (and I mean just) done the n/s/f on my D3
I went for a s/h unit £15, it can be taxing but very do able powerful uk have done a few utube clips changing them
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #624009 Mon May 02 2022 3:25pm
karlos01
thanks for that I'll give them a look up been looking at it today and it locked a couple of times them sometimes it won't
so new mechanism it will be
Post #624015 Mon May 02 2022 6:03pm
riverblanche
its most likely to be the little motor inside the actuator thats passed its best, you can replace just that part about £5 but you need to take the actuator out and strip it down to replace the motor and your best stripping it first to make sure which motor to order, shaft length and gear on the end Question
so unless you have a selection ready its easier ( Whistle ) to replace the full unit.
My wrist and forearm are showing the signs of fat arm inside a small door space this morning Laughing
here is a link to when I did our FL2 locks, its a L/R thing Laughing
https://www.freel2.com/forum/topic35541.html Porsche Cayenne 2022
Post #624023 Tue May 03 2022 1:57pm
karlos01
thanks folks I'll have a look over the weekend
Post #624024 Tue May 03 2022 5:35pm
