Home > Technical > horn not working
I had it as a a pink/orange wire
Post #623871 Tue Apr 26 2022 8:16pm
Definitely Purple/Orange on the wiring diagram I looked at, not Pink (PK) I don't think. What colour wire do you have at Pin No. 23 on connector C0580 at the CJB ? as a later diagram mentions Red/Orange but that may be facelift car.
Post #623873 Tue Apr 26 2022 9:40pm
Arh, thanks Col
Post #623882 Wed Apr 27 2022 11:17am
thegolffather
United States 2013 Range Rover Sport 4.4 V8 HSE Lux Siberian Silver
I wonder what happened to this thread did the OP ever sort out the horn issue? I am in the same boat
Post #644025 Tue Sep 03 2024 5:30am
Unfortunately that happens a lot. A thread is started by a new member looking to sort an issue and then they disappear. The OP hasn't posted on here in over 2 years so likely we'll never find out, sadly. 2012 SDV6 - it's missing a couple of cylinders
Post #644028 Tue Sep 03 2024 7:11am
thegolffather
I really need to sort this out as it will not pass safety inspection Confused 1973 Clubman GT * 2013 MB C250 * 2013 BMW X1 * 2013 RRS HSE Luxury * 2016 Mazda MX5
Post #644040 Tue Sep 03 2024 11:01pm
Not a auto electrician and always thought the horn relay was built into the CJB for some reason, but looking at this wiring diagram it looks like it is actually a separate relay in the engine bay fuse box, R5 top left by the bulkhead assume would be same on a left hooker but not sure + fuse no.25 so might be worth checking out, or with the aid of wiring diagram rewire some how, only a suggestion as said not a auto electrician.
Post #644041 Wed Sep 04 2024 12:15am
thegolffather
I found a relay for the horn inside the fuse box in the engine compartment. I was able to test the horn, fuse except for the relay and the clock spring. This is how the relay looks like:
https://www.rrsport.co.uk/gallery/albums/u...relay.jpeg 1973 Clubman GT * 2013 MB C250 * 2013 BMW X1 * 2013 RRS HSE Luxury * 2016 Mazda MX5
Post #644045 Wed Sep 04 2024 4:28am
Have you checked at the C2240R/C2238R plug/connector for a feed from the clockspring? look like a Green/Brown wire, could you also substitute the relay with one of the others to test that, as I'm sure one of them will be the same at least.
Post #644047 Wed Sep 04 2024 5:00am
Relay moved on facelift models it seams
Post #644051 Wed Sep 04 2024 8:31am
thegolffather
It is the only grey colored relay 1973 Clubman GT * 2013 MB C250 * 2013 BMW X1 * 2013 RRS HSE Luxury * 2016 Mazda MX5
Post #644066 Thu Sep 05 2024 1:41am
thegolffather
The diagram is blurred could not really read the letters and numbers, but I will try and research. I do not think the relay is bad because the horns chirp when the car alarms. 1973 Clubman GT * 2013 MB C250 * 2013 BMW X1 * 2013 RRS HSE Luxury * 2016 Mazda MX5
Post #644067 Thu Sep 05 2024 1:43am
View the diagram in "my gallery" you can enlarge it then, are you sure it is the horn's "chirping" and not the alarm sounder by the abs pump/master cylinder/servo?
Post #644068 Thu Sep 05 2024 5:59am
thegolffather
after using the car the radio control buttons on the steering wheel also do not work in addition to the horn. Could this indicate that the part at fault is the clock spring?
When I try to lock the car with the door open the horn alarms. 1973 Clubman GT * 2013 MB C250 * 2013 BMW X1 * 2013 RRS HSE Luxury * 2016 Mazda MX5
Post #644400 Thu Sep 26 2024 12:47am
MikeBell36269
I does look that way.
Post #644419 Thu Sep 26 2024 2:40pm
