Home > General > Body Off |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9010 |
Loosen and tighten the top mount nuts for the struts? If you need to replace the struts, not having them seized from a decade plus of crud would make the job easier. With the body off, access to the nuts is simple.
Sat Apr 23 2022 1:29pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 |
Sun Jul 17 2022 9:43am |
John1311 Member Since: 05 Jul 2012 Location: Devon Posts: 40 |
when my turbo went in my l322 - I purchased 2 off ebay and got the garage to change both while the body was off 2016 Range Rover Sport SDV6 autobiography (MY17)
Mon Jul 18 2022 9:03am |
When mine was body off to replace the crossover pipe, I had them replace the fixed brake lines that run along the chassis. Easy peasy with the body off. 2012 SDV6 - it's missing a couple of cylinders
Wed Jul 20 2022 7:48am |
