![]() | Home > Technical > Digital fuel gauge fault |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
TECHNICAL BULLETIN
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Can still email a pdf copy of complete bulletin if wanted, not sure what I'm doing but have managed to upload PDF file to my gallery as well. Need to work out how to add to post sometime. Might help anyone else who has similar problems.
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 ![]() ![]() ![]() |
My 2010 RRS developed this fault. Fuel gauge suddenly reads empty, then works for a while and then reads empty again. I've just had it repaired as per the tech bulletin above - i.e. a fault with the connectors.
Grizzly_Al Member Since: 10 Jun 2017 Location: Farnborough Posts: 15 ![]() ![]() ![]() |
Just had this very same problem with my 59 plate RRS, its only been a day so far, do I have to drop the tank to get to the sender unit ? I tried removing the rear seats to see if there was an inspection cover but couldn't find one |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
From memory, there are 2 senders in the tank.
https://drive.google.com/file/d/15vRZH1JCy...sp=sharing
Awesome thank you guy's |
