Home > General (L494) > L494, Main battery Replacement instructions |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1176 |
Hi chaps,
Sat Apr 02 2022 4:01pm |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 |
the varta one is the closest and known brand, not sure on the others but also the price is reflective im guessing, Id always go known brand with a battery, until some of the other are tired and tested, too many copies about that are never to be found again should you need to claim on the 5yrs warranty. If a jobs worth doing, get a someone who knows what they are doing to do it!
Sat Apr 02 2022 6:30pm |
Yeah, thinking the Varta or the Exide are the ones to go for.
Sun Apr 03 2022 10:23am |
Stealer will be just that grossly over prcied and I dont think they are JLR branded except when new in so i wouldnt waste your money the Exide is the OEM battery
Sun Apr 03 2022 10:31am |
Darn it, I put the car on my Ctek on AGM Recon mode for 2 days, and it showed the battery as full.
Mon Apr 04 2022 12:11pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 915 |
12.6v is about 95% charged. Stick it back on your ctek at normal charging, not recon
Mon Apr 04 2022 12:21pm |
thanks, but this is the original battery (2015), so 7 years is about right to be needed a new one. --
Mon Apr 04 2022 12:36pm |
I just replaced mine as most batts have a 5yr warranty and LR's you get about 3yrs its also worth looking at the the little battery too unless it a capacitor.
Mon Apr 04 2022 1:41pm |
^ thanks, I thought as much about the BMS, so I plugged in my IID and cleared all faults.
Mon Apr 04 2022 1:47pm |
is it the GAP IID as that has a dedicated BMS reset function built in? So the codes i dont think will make much difference. new battery is the best option to start with as its old and once they fall off they are hard to recover. Often if the lights were on and the battery has been flattened past 50% it can cause damage that even reconditioning canst fix so on an older battery its not worth bothering.
Mon Apr 04 2022 4:31pm |
Oi vey, now I need a new back
Tue Apr 05 2022 8:49am |
no worries chap a spa day sounds great! maybe somewhere like the Maldives would be ideal!
Tue Apr 05 2022 10:29am |
