Home > Technical > Global Open and Close
AndyCHO
Australia 2010 Range Rover Sport 3.0 TDV6 SE Ipanema Sand
I was playing with suspension height changes today using the GAP IIDTOOL and decided to have a look through the CCF and noticed that Global Open / Close was not turned on..
So I turned it on, uploaded the new configuration etc..
Interestingly, Global Open works on all the windows but not the Sunroof.
Global close works on the rear windows and the passengers front, but not the drivers front or Sunroof.
Where do I start troubleshooting on this? I need to check the Auto up on the Driver side window but I know the Auto (one touch) down works.
Post #623298 Sat Apr 02 2022 6:05am
You will no get the global closing to close the sunroof, L/R forgot to include the software in the system and never did a update so you can lock the car, arm the alarm and leave the sunroof wide open with no bleep or indication that it is open. However if you have the sunroof open switch the car off, climb out the window without opening the door then lock the car it will work. You may think I'm kidding but try it. Or open the window, leave the car running, get out of car and shut the door, lean through the window and switch the engine off and then try it, it will work and close the sunroof.
Post #623299 Sat Apr 02 2022 7:01am
Posted this about 7 years ago.
https://www.rrsport.co.uk/forum/topic40348...of+closing
Post #623301 Sat Apr 02 2022 7:28am
AndyCHO
OK... well that sorts the Sunroof part, now I just need to figure out the Drivers window.
Havent had a chance to check the Auto up operation yet. I will do that tomorrow.
There are some glaring omissions on these cars... I love it.. but it could have been so much better with a little thought.
Post #623305 Sat Apr 02 2022 8:43am
AndyCHO
So... other than the Sunroof the Global close issue is sorted.
Simple as re-setting the one touch up on the drivers window and it all works just as it should.
Post #623307 Sat Apr 02 2022 10:36am
