Home > General > Rear windows not working from all switches
stephen_dalton
United Kingdom 2006 Range Rover Sport TDV6 Autobiography Arctic Frost
Hello my rear window have stopped working they have been a little dodgie for some time now I have checked all fuses I had to power the back one up via a1 2volt feed to get it to close,any help would be very grateful thanks rrs 06 diesel hse
Post #622930 Fri Mar 18 2022 6:44pm
Could be :
Wiring in the tube to the drivers door maybe. So they start working if you hold the switch while opening the driver door while switch held to open
Or drivers master switch
Or built in relay
Post #622931 Fri Mar 18 2022 6:47pm
stephen_dalton
Hello just tried with driver door open still the same I thought all window ran from a centre relay thanks .
Post #622932 Fri Mar 18 2022 7:01pm
stephen_dalton
Post #622933 Fri Mar 18 2022 7:06pm
If you suspect wiring to the drivers door, repair is something like this:
Haven't done it myself.
Unplug drivers door from the car chassis frame
Pull the tubing back
Inspect the thick grey wires and green wires for breaks or lumps (lumps are usually breaks)
There are 2 grey/red and 2 grey/orange wires (one for left rear window, one for right)
If in doubt, you could cut the insulation off with a knief around the lump to see if the copper wire is ok inside or not
As a temporary repair you could join the wires and see if that fixes the problem.
But for a lasting fix at much as possible wire down the tube length should be replaced.
Green/brown powers right rear window
Green/blue wires power left rear window (and another for front)
The grey/yellows only prevent the rear switches from working (like the child switch)
While you are at it, check the thick black wire. This is the earth and stops everything from working and makes the door indicator do weird things
Post #622947 Sat Mar 19 2022 10:11am
stephen_dalton
Thanks pal your a star will give it ago
Post #622949 Sat Mar 19 2022 11:56am
