![]() | Home > Technical > tdv8 rr sport zf gearbox |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
I can't find any reference to the ZF spec with any Dexron 6 compatible oils...
DirtBuddha Member Since: 12 Jan 2022 Location: West Sussex Posts: 28 ![]() ![]() ![]() |
Never understood why people change the oil and not the filter. What’s the use of that? It’s like having a shower then putting all your dirty clothes back on. |
The reason they do not change the filter is because the entire thing is of poor design - you have to remove the entire gearbox sump which may require the removal of a cross member and lifting the engine. Why they did not design the sump to allow the filter to be easily changed I do not know - designers should be required to work on items they design.
Never understood why people would only replace less than half the oil... ![]() |
LesW Member Since: 30 Oct 2021 Location: Pays de la Loire Posts: 81 ![]() ![]() |
I thought the trans fluid was Shell ATF. A Cheshire expat in France.
Transfer case is manufactured by Shell, for JLR |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
The ZF gearbox is an "off the peg" item essentially. Its installation is down to LR. However, in something like a gearbox where the servicing might only need to be done once or twice in the vehicle's lifetime, having to mess around a bit isn't that onerous if the compromise makes other aspects of the vehicle better. It's more important to change the oil and thus the additives in the oil as they are the stuff that makes the gearbox work properly and also limit wear. Limited wear mean less stuff in the filter too. A full flush every 50-70k miles will probably do a lot to keep the gearbox healthy than changing the filter and 40% of the oil as in a "gearbox service". It's possible to fit a different bottom plate to the gearbox - it has a slightly different internal design. This can be removed without messing around. I had this done on my old TDV8. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mj1313 Member Since: 25 Jul 2021 Location: Bath Posts: 2 ![]() ![]() ![]() |
The gearbox has slowly got worse, i bought the Zf long life oil and pan/filter conversion. But i then took it to a local Landrover place to have the oil changed via machine i asked them about the filter they were not convinced it would make a difference. On the invoice it says 10ltrs of dextron 6 and some additive? Ive seen somewhere they must have this long life stuff ???? |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 ![]() ![]() |
As far as I know:
Why didn't you ask them to use the oil you'd spent money on? And Dexron 6 and an additive? I'd be asking them what exactly they've put in your gearbox. I wonder if the additive is just a tube of Dr Tranny. Sounds like you need to get them to do the job with the correct oil. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
