L320 looking for 18” / 19” wheels to fit
Any help please on finding some alternative wheel rims to fit a L320 TDV6 2010
Currently have 275/45 R20 I believe design style 1 have 9.5J ET53, and using General Grabber AT3 tyres
Having destroyed a couple of tyres recently, I am looking for larger tyre sidewalls for off road use, so ideally 18”, though know the stock sizes are 20” or 19”
Are there any 18” rims that will fit over the brakes etc, don’t have large brembos, for 3L L320?
If so, what am I looking for? And what tyre sizes?
Or are 19” the smallest rims you can fit?
If so, what rims can I look for and what tyre sizes?
Would like to stick to standard Range Rover wheels, but understand the sizes of bore and studs do vary, so what do I need to check to get the right wheels and get not caught out?
Thanks,
Mon Mar 14 2022 3:37pm
An 18 inch rim (and even a 17, I think) was available on the earliest L320 but not sure any would fit over the brakes on a 2010.
Compomotive make an aftermarket wheel - the PD1881. This does fit and then you can run something like the BFG KO2 tyre.
I run 255/55/19 on GG AT3s - not had any issues. If you have Brembos, then there's some that don't fit in 19s
The below style fit I think they're a pretty standard wheel.
Mon Mar 14 2022 8:53pm
255/55/19 here too on the same alloy rim style. Had both GG AT3 and Pirelli AT+ and had no problems so far - although the AT3 did get a couple of cuts near the end of their life that resulted in a slightly early replacement.
I think a lot depends on what type of off road stuff you're doing - a hidden bit of tree root or corner of a rock will take out any tyre if you hit it just wrong.2012 SDV6 - it's missing a couple of cylinders
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
