Home > General > Nzengines feedback
Finndog
Nzengines feedback
Hi has anyone used NZ engines in Rainham Essex ? My 2.7 engine has head gasket gone , Nz engines advertising £2400 refurbished engine supply and fit .
Post #622600 Tue Mar 08 2022 3:42pm
DirtBuddha
England 2010 Range Rover Sport TDV8 HSE Galway Green
I'm not familiar with them, but I recently had some work done on my 2010 RRS TDV8 by GND Motors in Rainham and was very pleased with it. They do a LOT of LR's and had several there when I took mine in. They also have stacks of LR engines piled from floor to (very high) ceiling on racking.
If interested, speak to Petyo Krumov 07809 350024‬ (don't worry... he's Bulgarian - not Russian! Very Happy ) ‭
Post #622607 Tue Mar 08 2022 6:59pm
Finndog
Hi and thanks for the info , I’ll call them .
Post #622611 Tue Mar 08 2022 7:29pm
If it really is a headgaskets. Just change the headgaskets. Either body on or off.
A better long term solution
If oil in the water, first check / change the oil cooler, located under the oil filter. Common issue
Post #622616 Tue Mar 08 2022 7:59pm
Finndog
Hi I have combustion pressure in the cooling system, the pressure relief is opening on the header tank cap. Can the head be removed with body on ?
Post #622667 Wed Mar 09 2022 10:46pm
The drivers head is easy to remove body on.
The passenger head is quite difficult, as the fuel belt is on the back, and its hard work to remove the belt cover.
I believe it is said it takes the same time to do body on or body off. It's just much easier job if the body is off.
Of course you can do lots of other jobs when the body is off. (read spend lots more money) (e.g. change brake pipes, rust proof) but I would rather spend money on that, than give it to an engine reconditioner of unknown quality
Post #622676 Thu Mar 10 2022 12:15pm
