Home > Advanced Factors > Automatic Transmission
Advanced Factors
Site Sponsor
This is a post to help people find the correct service parts for their Automatic Transmission.
6 Speed
8 Speed Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #622424 Fri Mar 04 2022 10:40am
Advanced Factors
Site Sponsor
6 Speed
Automatic Transmission ZF 6 Speed
Auto Transmission Oil ADV905 9.5 Litres Dry or 3.5-4.0 Litres Drain and Refill
Composite (Plastic) Sump Kit With Oil KIT401
Kit Contains:
Composite Sump Pan with built in Seal & Filter
7 Litres 6HP Oil TYK500050
Mechatronic Loom Seal
Metal Sump Conversion Kit With Oil KIT402
Kit Contains:
Metal Sump Pan Conversion (With built in magnets & with drain plugs)
Paper Gasket
Filter
Shorter Bolt Set
Composite Sump Pan (With built in seal and filter) LR007474
Metal Oil Sump & Filter Kit LR007474HD
Fitting this pan means you do not have to remove the cross member for access, simply drain your old sump, undo the bolts, lower and then either cut through the plastic filter spigot (allows oil upwards) or snap it off.
The new filter pushes into place and you can slide the new pan and gasket in.
We recommend use of a very small amount of non hardening gasket jointing on the gasket and on the bolt threads, do not over tighten the bolts as this causes leaks.
We also recommend inspection of the mechatronic seal (look up to where the wiring goes into the transmission, if it shows any sign of leaking replace it whilst apart as it is clipped on from the inside.
Kit contains:
Replacement Metal Pan (This pan has drain plugs in it - many others do not!)
Filter
Bolt Kit
Gasket
Replacement Gasket & Filter for the Metal Pan Conversion 100399
Oil Filler Plug LR007610
Mechatronic Seal TZV500010 Paul Redding
+44 (0)23 8052 2776
Post #622425 Fri Mar 04 2022 10:40am
Advanced Factors
Site Sponsor
8 Speed
Automatic Transmission ZF 8 Speed
Auto Transmission Oil ADV911 8.5 Litres
Meyle Transmission Service Kit ZF8HP 8 Speed 3001351007
Kit Contains:
Meyle Transmission Sump Pan with built in Filter
Pan Bolt Set
Mechatronic Seal
8 Litres Meyle 8 Speed Transmission Oil
Meyle Transmission Sump Filter Set ZF8HP 8 Speed 3001351007/SK
Kit Contains:
Pan Bolt Set
Plug Set 8 Speed Auto LR023292
DrTranny Lubeguard Automatic Transmission Treatment DrTranny
The following parts only fit the Range Rover Sport L494 (2014 - onwards)
Gear Shift Trigger Repair Set L494 Sport 8 Speed LR117072
P Button - Park Release L494 LR086213 Paul Redding
+44 (0)23 8052 2776
Post #622426 Fri Mar 04 2022 10:41am
