![]() | Home > Technical > FUEL RETURN LEAKS |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 210 ![]() ![]() ![]() |
Recently changed drivers inlet manifold fo new , but twice I've had to sort the fuel return lines at the injector ports. I don't know if this is something I am doing wrong but maybe the small o rings have hardened.
Ok , have exposed the fuel return lines again on V8 and turns out to be the same connector that blew adrift the last time.
